Setting Text Height
JEFFJW9BB
Setting Text Height
JEFFJW9BB
I want my text to print out 3/16" high in a paper space drawing scaled 1 1/2 inch.  (11 x 17 print out)
I set up a text style that is 3/16" high and I selected it in the dimension style.
When I dimension the object and print it out it is bigger than 3/16 high.  Why??
Attached please see:
The floor plan is drawn on "Floor Plans TEST.dwg"
The dimensioning is done on "Plans Annotated test.dwg"
The paper space is on "Sheet1 test".dwg"
Thank you for your consideration.
0 Me gusta
Responder
Soluciones aceptadas (1)
557 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
Are the problem items AAI_DIM_Smaller and ARCH_HAND_TEXT_SMALL by chance?
Seems to be working fine
0 Me gusta
JEFFJW9BB
I am using "ARCH_HAND_TEXT_SMALL"
But I embarrassed to say that I need the letters to be 3/32 NOT 3/16.  My arithmetic error.  But,
I noticed you circled the annotation scale in the bottom right. Frankly I don't understand what this is or does.   The floor plan, my template, is set at 1/8".   I got it from an architectural firm that always does their plans at 1/8".  Is this bad practice?  It is really true that all drawing should be done at 1:1?
Why does it matter when I set the scale in paper space for what I need?
0 Me gusta
maxim_k
Solución aceptada
Hi @JEFFJW9BB ,
Try this:
Edit text style you are using in dimension style and dimension style itself in the Plans Annotated test.dwg:
Save drawing and look at the dimensions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
JEFFJW9BB
Thank you!
0 Me gusta
