selection window
selection window
selection window
Iv been using Autocad for twenty years. I would really like to use AutoCAD on a Mac but I'm having problems getting my selection properties to work as the same. Iv never liked the lasso etc and don't see where to get rid of that but that's not my problem.
In AutoCAD on a pc when I LMB and release it makes the selection. Rather LMB make selection and then LMB yet again. Basically I'm having to do double clicks just to do a selection. The option window in MAC just doesn't even remotely have the same options or info. I can tolerate some things and put up with the mouse delay that AutoCAD Mac has always had but could use some help fixing my window selection problem.
It should be LMB-hold-select-release,,,,, rather LMB-hold-LMB
Thanks in advanced, I really hope I can fix this.
best-
Josh
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous ,
I think you can find an answer here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-turn-on-off-Lasso-feature-in-AutoCAD-2015.html
"For Mac versions of AutoCAD and AutoCAD LT, type the variable name PICKAUTO at the Command line. Enter a new value of 1. (There are other possible values, but 1 will be the most commonly used, if lasso selection is not desired.)"
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks Maxim,
Not so much. I still have to click after making a selection each time.
maxim_k
Ah, yes.
PICKDRAG=1
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-46CBF4EF-E210-447D-AE6E-793249551640
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Ur an expert Maxim! Id buy you a coffee for that! Im an old school cad dinosaur, lol.
That fixed it!
best!
