Selection Cycling
Selection Cycling
Message 1 of 10
Selection Cycling
How can cycle through selections in Mac?
In the Windows version it is easy with Shift-Spacebar, but in Mac it doesn't work.
And I don't understand what the command "SELECTIONCYCLING" can do to solve this problem.
Replies (9)
Message 2 of 10
maxim_k
Look trroug this article: Selection Cycling Through Overlapping Objects in AutoCAD For Mac
And be sure to set SELECTIONPREVIEW=3 before using Selection Cycling.
In AC 2012 shortcut CTRL+W for toggle Selection Cycling seems doesn't work, but Selection Cycling with SHIFT+Spacebar works regardless of Selection Cycling state.
Everything should work.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
Thank you for your quick response. It was helpful!
Especialy to set the SELECTIONPREVIEW to 3 made the difference.
Martijn
Message 4 of 10
chriscai96
Observer
Observer
Hello!
 I'm having some problems with Selection Cycling
I would like to pick between two different objects but nothing happens
Different variables of systems are in these values:
  • SELECTIONPREVIEW = 3
  • SELECTIONCYCLING = 2
  • LEGACYCTRLPICK = 2
Message 5 of 10
maxim_k
Welcome to Autodesk Forums!
Hi Cristhian,
Do you follow the advices from the blogpost I mentioned?
https://macacad.wordpress.com/2011/04/12/selection-cycling-through-overlapping-objects-in-autocad-fo...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 10
chriscai96
Observer
Observer
Hi Maxim,
Yes i followed them
But nothing happened
Message 7 of 10
maxim_k
Did you turned on Selection Cycling with Ctrl +W shortcut?
Do you see CC icon near crosshairs when you hover over intersect objects?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
chriscai96
Observer
Observer
Yes
Message 9 of 10
maxim_k
It is little bit tricky, here how it works on my side:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 10
Angie_guy25
Hi. I also tried all the discussion here but it did not work in my CAD LT Mac. I also made sure the crtl+W is turned on still unable to have a way to select on multiple layer overlapping. What I am currently doing one by one I send to back in Order. Hoping I can use the fastest way in this case.
