Select an annotation object or
Message 1 of 11
I've entered some mode or done something so that every few clicks I do return my cursor to the "Select an annotation object or" mode. It keeps coming up and I've never experienced this before. I've never even used that command, I don't get why it's coming up. It's killing me. Help.
Replies (10)
Message 2 of 11
maxim_k
Welcome to Autodesk Forums!
Do you have this problem in all of your drawings?
Have you tried to restart AutoCAD? - Use QUIT command to close AutoCAD completely.
What prompts do you see in the Command window before that one you showed in your post?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
All my drawings, even after a full reboot. See attachment.
Message 4 of 11
pendean
Community Legend
Community Legend
Can you walk us through a command sequence example? You know, how can we retrace your steps exactly.
What is your AutoCAD version? What is your MacOS version?
Message 5 of 11
maxim_k
TEXTEDIT command starts for some reason. Does it start even if you don't touch anything in AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 11
Autocad product version N.49.M.324
OSX High Sierra 10.13.3
Basically it just pops up constantly. If I select a text module then unselect it it pops up about have the time. It's like it's set as a default mode.
What is the command sequence for that? I thought maybe it was something weird my mouse was doing but I've replaced my mouse with another and that still happens. It's the kind of thing that feels like there's a key on my keyboard half stuck or something.
Message 7 of 11
pendean
Community Legend
Community Legend
>>>...If I select a text module then unselect it it pops up about have the time...<<<
You might be double-clicking on it instead: so this only happens when you touch text objects, never anything else?
>>>>..What is the command sequence for that?...<<<<
TEXTEDIT command is what you appear to be launching with a double-click.
I wonder, just wonder, if you need to change the setting for PICKFIRST variable (look it up in HELP): what do you have it set to now?
Message 8 of 11
maxim_k
Can you verify also if you turned on some of the accessibility options for Mouse and Keyboard in the Accessibility pane of macOS System Preferences:
 Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 11
I believe I resolved it by typing TEXTEDIT and then entering 1, rather than 0.
Message 10 of 11
maxim_k
TEXTEDIT is AutoCAD command and you cannot change it from 0 to 1. Maybe you changed TEXTEDITMODE System Variable, which controls whether the TEXTEDIT command repeats automatically?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 11
Sure, that must've been it. I was in a text editing mode apparently.
