Anuncios
Scale
Scale
No aplicable
I really struggle with recieving engineer drawings then creating my own scaled layout.
Please see attached my final - Im trying to create an A1 layout with the whole of the details displayed on one page - but i can't get it to happen and I know there are little tricks that you can do.
Could someone please help me ASAP
Thanks.
0 Me gusta
Responder
299 Vistas
4 Respuestas
Respuestas (4)
maxim_k
But you already created A1 Layout with viewport showing everything in model space at scale 1:1000.
Can you clarify your question?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
Your LAYOUT1 is already set to an ISO A1 Expanded sheet size, the viewport is set to a 1:1000 scale, and all looks good and ready to go: other than AUDIT command finding a bunch of errors in the file's database you seem to have nailed it.
What additional help do you need?
0 Me gusta
john.vellek
Hi @Anonymous,
The current layout is scaled properly but I am guessing that the layout is the one used by the engineer. Can you give me a better idea of what you want on your layout? Perhaps attach another sample drawing or picture of what you are trying to achieve?
To scale the existing viewport, simply double-click inside of it and then go to the Scale list at the bottom right of your toolbar and select a different scale.
Once you have scaled the viewport switch back to paperspace and change the location and size of the viewport as necessary to accommodate your other work that you want displayed on the layout.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
