Scale line weights in viewport without changing viewport scale
CMINNICK37F3QE
Observer
CMINNICK37F3QE
Observer
Observer
The CTB I use is perfect for 1'4"=1'-0" floor plans. If I have to print at 1/8", the line work gets muddy. How can I control the line weight of a single viewport? In Vecrtorworks, for example, you select the viewport and tell it to print lines at 50% . . . while keeping the drawing scale in tact.
0 Me gusta
Responder
256 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Hi @CMINNICK37F3QE ,
Do not use CTB to control lineweigts, instead use lineweight property for Layers in all viewports (1) and Override Layer Properties in that single Layout Viewport (2):
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
CMINNICK37F3QE
Observer
Observer
Hello @maxim_k  ,
I get that, but I was hoping there was a less fussy solution, like the Vectorworks one-button solution I refer to. If this is the easiest way, then I will use it.
Thanks for your help.
0 Me gusta
moneumiko
Do you have this option on when printing? If yes, maybe try to untick it?
0 Me gusta
moneumiko
I always have that option off, and my drawings look correctly.
0 Me gusta
