I have the free trial for AutoCAD 2016 for Mac right now. It should be expiring soon, but I have made a drawing that I wish to keep saved after my free trial is up. Is there a way for me to save this drawing to a hard drive and then be able to view on any computer? Or does the computer I am trying to view it on also need AutoCAD?
(Also on this AutoCAD file, I have texts and images that I have to zoom in on to see because the picture is quite large. If there is a way to save the drawing, is there a way to be able to zoom in on those portions as well?)
Please let me know, I would greatly appreciate it.
Thanks!
Adam
@Anonymous
john.vellek has edited your subject line for clarity: Saving a drawing on a free trial (?)
Solved by jayhar. Go to Solution.
Solved by john.vellek. Go to Solution.
Solved by maxim_k. Go to Solution.
yes you can save to your harddrive, you can open your file to any computer, yes you need autocad software if you need to do something with your drawings but if you want just to view you can download autodesk DWG trueview.
yes
thanks
when you save it ...all of your works will be saved and you can get it whenever you need .
you can save it where ever you want and you can view it in any other computer that can read your format type .
uninstall AutoCAD from your computer didn't mean that your drawing will be damaged . <dwg extension files can be read from any other AutoCAD software that match it's format type .
I think everyone missed the point about you being on a MAC.
There is no free viewer software for a MAC from Autodesk to install after the fact. If you just want to look at your file you can use the free web viewer https://viewer.autodesk.com/
If you want to do more than just look at it there are dwg-compatible CAD programs to use on your MAC if you are not going to subscribe to AutoCAD for Mac.
Hi Adam,
Yes, you need to create named views with VIEW command, then you can simply navigate between these views.
If you need free DWG viewer for macOS, you can try to use this one:
https://www.zwsoft.com/zwcad/viewer/
It works for me fine.
Hi @Anonymous,
As @maxim_k indicated, there are some Mac Cad viewer applications available. You also have the option of printing your drawing(s) to PDF and that might allow you the most flexibility. Please let me know if you need help doing this and I am happy to help.
Hello friend
The trial software is no different than the software used with a paid license, other than it expires at some point.
You can save any drawing file and use a reader or other CAD software (such as BricsCAD perhaps?) to view and edit the same drawing file at any point down the road.
To view on *any* computer, you'll need some kind of CAD viewer, such as Autodesk DWG Trueview, or BricsCAD Shape, or Bentley View, etc. (Autodesk also has an online viewer, where you upload your DWG to them, then it displays in the browser)
You could also print the drawing to PDF if you just want to send the drawing to others who do not have a CAD viewer and don't want to install one.
Just keep the DWG file, because the PDF does not contain the same intelligence as the DWG file. It's just a print.
