I am also facing same problem in mac and I am using auto cad 2019 please suggest any other option for solve this issue
@ben4V6NL wrote:
I've been having the exact same problem with this and have spoken to both Apple and Autocad.
Essentially it seems to be an issue with Autocad software, which has been logged, so hopefully will get fixed.....
The work around, suggested by autocad is to turn off the backup files using the ISAVEBAK command, and setting this to 0 (zero).
Not ideal, as you loose the security of the back up file, but it does seem to solve the problem, and autosaves still work as normal.
