I know how to set the right mouse click to 'enter', but it doesn't work correctly it seems. If I select an object before entering a command, then enter a command, then right click - the shortcut menu appears instead of acting as 'enter'. If I enter a command, then right click to accept command, then click object, then right click or enter everything works fine. But I want to click on an object with no command entered, then enter the command, and then right click for enter. In this scenario it doesn't work and I have to lift my hand off of the mouse and click enter on my keyboard.
Is there a fix for this?
thanks
Solved by maxim_k. Go to Solution.
yes, the problem appeared upon new install of 2020.
I have migrated settings but found a number of items that have required adjustment.
I do have additions, however, dont feel they are causing the problem. I use simple support path variations, lsp and customization of files. The problem occurred prior to install of the additional paths.
Ive run an AutoCAD repair, but am wondering if I should uninstall and then reinstall in the event there may have been glitches in the original install process. ???
