reset remorse
reset remorse
No aplicable
on my desktop computer, i inadvertently reset my program & now when i try to viewport freeze a layer, it turns off entire model space layer
on my laptop, the layers can be individually frozen in same viewport, so it must be a setting on my desktop machine
please advise... thanks
0 Me gusta
Responder
Soluciones aceptadas (3)
626 Vistas
7 Respuestas
Respuestas (7)
Emmsleys
Hi @Anonymous,
On your desktop, have you noticed if this happens even in a new file? Or is it only with existing files?
Sarah Emmsley
Technical Support Specialist
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
You need to change settings in LAYFRZ command in such a way that it uses the option "Vpfreeze" instead of "Freeze".
Look at the command prompt options you need to type (marked in red):
Command: LAYFRZ
Current settings: Viewports=Vpfreeze, Block nesting level=None
Select an object on the layer to be frozen or [Settings/Undo]S
Enter setting type for [Viewports/Block selection]V
In paper space viewport use [Freeze/Vpfreeze] <Vpfreeze>: V
Select an object on the layer to be frozen or [Settings/Undo]TEXT
Layer "TEXT" has been frozen in this viewport.
Command:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Solución aceptada
Hi @Anonymous,
Following up on your thread, please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
0 Me gusta
No aplicable
thanks sarah,
i've solved the vp freeze issue & now a new problem, perhaps related to mac OS X sierra
now my pdf xref's appear on screen, but aren't printing... they do print on mac w/ old el capitan os
any help would be appreciated
0 Me gusta
maxim_k
Solución aceptada
Update 4 is here:
http://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-2016-for-mac-update-4-is-here-now-it-is-...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Solución aceptada
Hi @Anonymous,
Please apply the update 4. Post back with any updates and or issues that you run across
Sarah Emmsley
No aplicable
thanks
0 Me gusta
