Removing block libraries in AutoCad 2023
bret_wieseler
Message 1 of 14
bret_wieseler
Hello.
My block libraries are being duplicated in the drop down menu (see attached image).  I would like to remove them and reload the libraries, but I can't find any way to remove them.  Does anyone have any advice?
Thanks in advance.
iMac | 3.6 GHz 8-Core Intel Core i9 | 64 GB | Sequoia 15.5 | Autocad LT for Mac - 2024.2
Replies (13)
Message 2 of 14
maxim_k
Hi @bret_wieseler ,
There is no official way to remove block libraries, but you can try this workaround:
1/ Quit AutoCAD
2/ Go to the "~/Library/Application Support/Autodesk/AutoCAD 2023/R24.2/local" folder
3/ Open HKCU_V1.plist file in plain text editor. My advice: make a backup of this file in case something goes wrong.
4/ Delete all keys "HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.BLOCKLIBRARIES.LIBRARYn" keys in this PLIST file (LIBRARYn - should show as LIBRARY1, LIBRARY2, etc.)
5/ Delete string values in "HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.LASTACCESSEDLIBRARY" and in "HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.LASTACCESSEDLIBRARYNODE" keys.
Now BLOCKSTREAM related keys in the HKCU_V1.plist file should look like this:
<key>HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.@</key>
<string>@Invalid()</string>
<key>HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.BLOCKLIBRARIES.@</key>
<key>HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.LASTACCESSEDLIBRARY</key>
<string></string
<key>HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.LASTACCESSEDLIBRARYNODE</key>
<string></string
<key>HKEY_CURRENT_USER.DIALOGS.BLOCKSTREAM.LASTCRASHEDRECENTDRAWING</key>
<string></string>
6/ Save HKCU_V1.plist file and launch AutoCAD
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 14
bret_wieseler
Thanks, as always!
Message 4 of 14
alina.balkanskaia
Hello, @bret_wieseler! Glad to see you in Autodesk Community! Thank you for marking the correct answer as the Solution cos it makes it visible and helpful for other users!
Alina Balkanskaia
Message 5 of 14
jacquijoubert67
Hello, for some reason my desktop folders have ended up in my block library see screenshot below, how do I delete them?  I have looked at your answer but cannot find..~/Library/Application Support/Autodesk/AutoCAD 2023/R24.2/local?  Im on a Mac and new to AutoCAD so any help would be appreciated.
Message 6 of 14
maxim_k
Hi @jacquijoubert67
Open Finder, use menu Go->Go to Folder, copy this path to clipboard:
And paste it to the search field:
 Hit Return and you are there.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 14
jacquijoubert67
Hi, thanks for your reply - I found the file, did the edit, saved the .pline file but on re-launching AutoCAD the pesky libraries are still there!
I have uninstalled AutoCAD 2023, re-installed AutoCAD 2024 and opened a new template only to find that the unwanted folders have transferred.  Any ideas on what I could try next greatly appreciated:)
Message 8 of 14
maxim_k
Jacqui,
Is your main problem that you cannot scroll dropdown list on the Block Libraries palette?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 14
jacquijoubert67
Hi - I can scroll the dropdown list on the libraries palette but there are 2 items on the dropdown list that I want to delete.  Since installing AutoCAD 2024 and restarting my computer, all the folders/contents in these 'libraries' has gone so that's good.  I would now like to delete the two unwanted items on the dropdown.  See screenshot - I want to delete 'SA Trip Nov 23' and 'Desktop'  (I still don't know how these two items ended up in my library palette), is there a way to delete these items?
Message 10 of 14
maxim_k
Can you attach here your HKCU_V1.plist file which is located in
~/Library/Application Support/Autodesk/AutoCAD 2024/R24.3/local
folder?
I will try to help you to remove these items and then send it to you. You will replace your current HKCU_V1.plist file with edited one.
You need to compress it before attaching to the post.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 14
jacquijoubert67
Thanks so much.  File attached
Message 12 of 14
maxim_k
Hi @jacquijoubert67 ,
Quit AutoCAD
Backup your current HKCU_V1.plist
Download attached archive, extract HKCU_V1.plist from it
Replace your current HKCU_V1.plist with one from the downloaded archive
Launch AutoCAD and verify Blocks palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 14
jacquijoubert67
Hello - thanks for your reply, I really appreciate it.  Unfortunatley the two unwanted libraries names are still in the drop down after replacing the HKCU_V1 plist in my finder with the one you edited.   Frustrating to say the least.  There is no information/folders in these libraries so I think I'll just have to live with the unwanted items in the drop down list.  Thanks again 🙂
Message 14 of 14
maxim_k
Hi Jacqui,
@jacquijoubert67 wrote:
...Unfortunatley the two unwanted libraries names are still in the drop down after replacing the HKCU_V1 plist in my finder with the one you edited.   ...
Strange.
I tried to remove block library folders with this method on my side and after I launched AutoCAD I got this:
Are you sure you QUIT AutoCAD before replacing PLIST file?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
