remove color in selection area
bertbert
bertbert
I recently started using an 2022 LT version. Is there any way to turn off the color in the selection area?
Thanks in advance,
BB
Valentin_CAD
@bertbert ,
... Is there any way to turn off the color in the selection area?
In Options > Selection (Tab) > Preview "Visual Effect Setting" uncheck "Indicate selection Area.
Also consider: How to change the highlighting of selected objects in AutoCAD
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
bertbert
thank you for your answer!!!
That is what I previously did on my PC. With the MAC / OS these tabs are missing.
Is there any comand for this?
pendean
Community Legend
Community Legend
WINDOWAREACOLOR and CROSSINGAREACOLOR are the variable names, HELP should explain usage.
Valentin_CAD
@bertbert ,
SELECTIONAREA (System Variable) = 0
https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/201...
Emilio Valentin
bertbert
SUPER!!!
Thank you very much!
Such little things that can be so enoying!
Have a good day!
BB
