Reference files not found
jcabinnga
jcabinnga
I'm getting a warning for "Reference files not found".
It is for a simple *.jpg file attached to a client border.
How can I make this file show-up and NOT get the reference warning?
The same files do not do this for windows 10 Autocad 2019 - only Autocad for Mac 2019?
What am I missing?
rkmcswain
OLE objects (which are not references) do not display on MACs.
I suspect the missing reference message is referring to something different. Click on "open the external references palette" to see what it's looking for. Place this file in the same location as the DWG and reopen.
maxim_k
What am I missing?
Hi Jack,
As @rkmcswain mentioned in his reply the case is not in OLE object, which cannot be displayed on Mac in any case, but in externally referenced image. You need to open External References palette and look for an alert in it. Most likely AutoCAD cannot find the external reference (image file) in the saved path. You have to adjust this path manually on Mac side, or use "Mac and Windows server path mapping" feature to allow AutoCAD to find the image file on server.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
