Anuncios
Recently updated to 2022 font (Heiti SC reg) displaying on sheet but not displaying properly in pdf created using DWg to PDF.PC3
lauraQH6G3
lauraQH6G3
Hi!
I and others in our practice have recently updated to 2022. We use the font Heiti SC regular. This displays when in autocad but once PDFed using dwg to pdf. pc3 the text errors as in the below screenshot. The font is correctly installed on the system, it has been replaced, to check it is not corrupt, this had no impact. Solution welcome?! tried allsorts and had no luck so far. I am on Mac OS Monterey 12.2
0 Me gusta
Responder
1.788 Vistas
28 Respuestas
Respuestas (28)
pendean
Community Legend
Community Legend
Which PDF driver did you use and how is it set to handle/capture fonts?
0 Me gusta
lauraQH6G3
I used DWG To PDF.Pc3
Unsure what the second question means sorry
0 Me gusta
lauraQH6G3
0 Me gusta
maxim_k
Hi @lauraQH6G3 ,
Try tu use "Convert all text to geometry"
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
lauraQH6G3
Thanks Maxim, that is what I have been doing as a temporary fix. Will continue to do this until I there is a full solution.
0 Me gusta
maxim_k
Laura,
>>>>Heiti SC regular
Is it commercial font?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
As a test only, does the visual aspect of those fonts improve if you select this option?
0 Me gusta
lauraQH6G3
Standard Mac Font which comes on the system
0 Me gusta
lauraQH6G3
Yes this is what I have been doing as a short term fix
0 Me gusta
maxim_k
Then I will check it on my side.
What macOS version do you have on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
lauraQH6G3
Thanks!
0 Me gusta
maxim_k
I cannot reproduce this issue on macOS BigSur 11.6.3
 Have you installed >>>this<<< Update?
Can you share your drawing here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
Can you share your PDF with the odd-looking text here please?
A portion of your DWG with that same text in it would be nice too, if you can.
0 Me gusta
lauraQH6G3
Thank you I will try this
0 Me gusta
lauraQH6G3
Hi, this update will not work as I have autocad LT, is there a LT version of the update?
0 Me gusta
lauraQH6G3
Please see files attached
0 Me gusta
lauraQH6G3
All the following are installed
0 Me gusta
maxim_k
>>>>>this update will not work as I have autocad LT,...
Sorry it was my fault.
But now I see that you have all the updates installed.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Hi @lauraQH6G3 ,
I tried to save PDF form your drawing and all text looks correct (see attached PDF).
As I wrote before, I have macOS Big Sur  on my Mac, maybe the case of incorrect font representation is macOS Monterey, but I'm not sure.
Please post screenshot of Print window at the moment when you save drawing to PDF.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
