Rearranging multiple page layouts
RoxanneRae
RoxanneRae
I'm working on autocad for mac 2020. I have approx 65 page layouts that need to be re-arranged. Dragging them one by one across the ribbon bar at the bottom seems to be the only solution I can find, which is painful. I can only view 9 layout tabs across the bottom of my screen at a time, so dragging over is a mult-step process. Is there a way I can view all of my layout tabs in a list and rearrange them there??
Thanks!
Roxanne
0 Me gusta
Responder
Soluciones aceptadas (2)
3.817 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Solución aceptada
Hi Roxanne,
Have you tried QUICKVIEW command:
You can drag layouts inside QUICKVIEW window:
https://help.autodesk.com/view/ACDMAC/2020/ENU/index.html?guid=GUID-E74231E6-96B6-4EF5-AA28-4AC76D24...
https://help.autodesk.com/view/ACDMAC/2020/ENU/index.html?guid=GUID-5B4F3E58-1963-4355-A710-BA60D540...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
RoxanneRae
THANK-YOU Maxim!! A much easier task ahead of me now. Appreciate your time!
0 Me gusta
Leaf.chai
Solución aceptada
Just like Maxim said, QVIEW palette can solve this issue:
1. Run OVIEW command.
2. Drag and drop the Layout you want to re-arrange.
In QVIEW palette, you can also multi-select layouts by HOLD SHIFT or CMD key to select. Then you can multi-delete them. Multi re-arrange is not supported now.
Leaf
AutoCAD Test Engineer
Leaf Chai
AutoCAD QA Analyst
0 Me gusta
No aplicable
Nice, that is interesting
0 Me gusta
