Re: Cannot join polylines
Apex-Solutions
Message 1 of 8
Apex-Solutions
Hi
Just to confirm.  You are not using AutoCAD LT 2015?
If this is the full AutoCAD, which I assume it is then please head over to this knowledge base to fix the issue where the AutoCAD Flatten command is listed as an unknown command.  https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Using-an-Express-Tools-c...
Regards
Marnus van Staden
Technical consultant & Civil 3D support Specialist
Prokon Software Consultants
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
________________________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
Apex Solutions Youtube Channel
Replies (7)
Message 2 of 8
maxim_k
Hi Marnus,
For the moment there is no FLATTEN command in AutoCAD for Mac.
The article you referenced here is about AutoCAD for Windows, but here is AutoCAD for Mac Forum.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 8
Apex-Solutions
Hi
It would seem that the reply I posted was removed from the original poster...??
Regards
Marnus
Kind Regards
Marnus van Staden
Message 4 of 8
Apex-Solutions
Hi
It would seem that the reply I posted was removed from the original poster?
Regards
Marnus
Kind Regards
Marnus van Staden
Message 5 of 8
maxim_k
Yes, looks like OP deleted the original post at the time when you wrote the reply.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 8
Apex-Solutions
https://forums.autodesk.com/t5/nastran-in-cad-forum/cannot-join-polylines/m-p/7200572#M2045
Still there
Regards
Marnus van Staden
Kind Regards
Marnus van Staden
Message 7 of 8
maxim_k
I see.
So you already answered OP's question there.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 8
Apex-Solutions
Found the answer this morning after you mentioned that the Flatten command does not exist in AutoCAD MAC.
Thanks.
Kind Regards
Marnus van Staden
