Random wipeouts appearing when drawings are published
katherineWB4MA
katherineWB4MA
My drawings look correct in paperspace, but when I publish the drawings random squares of white show up over the drawing. I've double-checked and there are no wipeouts in these locations. This seems to be a problem on random sheets in the drawing set, but others even within the same files are plotting correctly. Has anyone had this problem/been able to make the sheets plot correctly? I've attached screenshots of the elevation in paper space vs published to show the problem.
Replies (16)
pendean
Community Legend
Community Legend
Share that portion of the DWG file if you can, lets all have a look.
AutoMarcus
guys i think this may be related to the transparency problems with publish that we are seeing as well
all happened since the latest hotfix
just a hunch
cadffm
If someone talk about DWG, upload this dwg (not just images)
If someone talk about an update, we have to talk about the product and productversion(command INFO) first.
Or?
Sebastian
AutoMarcus
Autodesk® AutoCAD® 2020.1.2 Update PDF Edit Hotfix
katherineWB4MA
Unless the update was automatic with the 2020 version I don't believe I've downloaded the update. Also if it's helpful I'm using AutoCAD LT mac version. Thanks for the advice though!
maxim_k
And what about sample drawing with problem? Can you share it here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
katherineWB4MA
Hi, thanks for the help. Here is a DWG of one of the files having these wipeout issues.
maxim_k
I tried to reproduce your problem, but can't  - see attached PDF, created on my side.
Can you share PDF which shows the problem?
I also noticed that some of TTf fonts was not included in E-transmit: GothamLight and Univers. Do you have them on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
katherineWB4MA
Hi, thanks so much for trying to help me out. When I publish the drawing it looks like the attached image. I've quit and restarted my AutoCAD several times, I've audited and purged the drawing, not sure what else to try 😕
maxim_k
I see you use AutoCAD 2018 LT for Mac, didn't you?
And what macOS do you have on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
katherineWB4MA
Hi, I am using macOS Catalina 10.15.1.
maxim_k
You wrote in your initial post:
"This seems to be a problem on random sheets in the drawing set, but others even within the same files are plotting correctly. "
Does these layouts contain text objects based on Gotham Light, Gotham Bold or Univers fonts?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
katherineWB4MA
Yes, they have Gotham Bold and light fonts, these are fonts I've installed to my AutoCAD base application..but these fonts also occur on pages that are publishing correctly. Could they be causing a problem?
maxim_k
Do you have them (fonts) inside AutoCAD application folder? If yes, you can try to remove them from there and install only in Font Book. Then relaunch AutoCAD and try to save PDF from problem Layout.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
katherineWB4MA
Hi, I never really solved this problem. When I downloaded AutoCAD 2021 the issue went away, but now it is happening again. I've removed all fonts from within the AutoCAD application itself, and again the issue is only happening seemingly at random, currently 3 sheets of my 64 page drawing set are having issues but they're all set up from the same base files with the same fonts etc. Any other advice of things I could try? Thanks for your previous advice!
maxim_k
Hi @katherineWB4MA,
The discussion moved to new thread for now:
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt-wipeouts-appearing-in-pdf-d-drawings...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
