Hi there,
I'm trying to install Autocad for student on my MacBook Pro (MacOS 10.15.2 Catalina). This is the error:
"Incompatible File System! Autodesk AutoCAD 2020 for Mac can only be installed on System drive formatted with Journaled HFS+ (Mac OS Extended Journaled) file system."
I've tried with Autocad 2019, 2018 versions, too and the error is the same.
Thank you for any help.
Thank you for your answer. Yes, I have a case-sensitive partition, but I tried also with a simple APFS partition, and it shows the same error.
I understand, thank you.
So the only solution is to format the system partition in a APFS file system?
Thank you
