I've updated to Autocad 2017 for Mac, and every time i try to open or create a file this error appears. When i press ok, it freezes and then crashes. Any suggestion?
Thank you
João
Solved by joaopedrosiopaalves. Go to Solution.
What operating system are you using? Can you check for Apple updates and see if the problem persists?
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
I met the same situation.
I'm running an AutoCAD 2017 student version and my operation system is MacOS Sierra.
When trying to open new templates or open a file, it shows "Exception in AcExperience.bundle ARX Command" and it freezes after clicking OK.
I was using macOs Sierra. I've uninstalled it, i even installed 2015 and 2016 versions, and there were always problems. The only solution that i found was to format my hard drive, and now Autocad 2017 is working fine.
Is there any other solution than formatting the hard drive?
I installed auto cad 2017 on macOs 10.12.3 however I can't even start the program. Before anything happens I get the same error as mentioned above... tried installing the hot fix but that doesn't work either as the program won't start.
Hi! I have the same problem with Acad2018, student licence, on High Sierra... Can you please help me.
