Quickcalc
Quickcalc
Quickcalc
I am using AutoCad 2020 for Mac and I am unable to use Quickcals. help asap
When I type it in the command bar it doesn't come up. It is not under tools either.
However when I want to create a new panel and I look for it there it its, but it appear.
HELP ASAP PLZ
pendean
Community Legend
Community Legend
"QUICKCALC is not available in AutoCAD for Mac.
Inside AutoCAD for Mac you can use only command line version calculator - CAL:
https://help.autodesk.com/view/ACDMAC/2020/ENU/index.html?guid=GUID-335A5FC6-7D8F-47CA-B479-26655CDE...
You can use this command transparently inside another command for calculations by adding ' before the command name:
'CAL
If you have full AutoCAD, you can also use AutoLISP expressions for calculations."
