Anuncios
Properties pallet does not show size of objects?
michaelVF8MS
michaelVF8MS
I'm using AutoCAD for Mac 2022, but this question is probably independent of platform. When I select an object, an 96" x 6" rectangle for example, nowhere in the Properties does it give me that information. What could be a more basic "property" of an object than its length and width, diameter, circumference, etc. There is a field labeled "Length," but that incorrectly gives the perimeter dimension. Since it is not possible to do math expressions in the input boxes (unlike every modern application) it would be helpful to have this property displayed. I'm thinking I must have something turned off by mistake that needs turning on. Any help is greatly appreciated.
Thank you,
MH Brown
Responder
353 Vistas
3 Respuestas
Respuestas (3)
pendean
Community Legend
Community Legend
screenshots please
0 Me gusta
maxim_k
Hi @michaelVF8MS ,
The rectangle created with RECTANG command is just regular closed Polyline object which can be created with PLINE command.
That is why it doesn't have Width and Length properties as real rectangle have.
AutoCAD doesn't have such object as "real rectangle".
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Hi Michael,
If you need "true rectangle", you can create simple Dynamic block.
I attached example of such block - P_Rectang. See attached drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
