Anuncios
problemas con la nueva version de autocad lt 2017
No aplicable
Instale la nueva version de Autocad LT MAC
cuando ejecuto un comando cualquiera se desaparece todo en la pantalla quedando solo la barra de arriba de comandos y todo se congela se queda pensando
toca forzar la salida
que debo hacer para solucionar este problema
mi correo es jrbayonaf@gmail.com
gracias
0 Me gusta
Responder
Soluciones aceptadas (1)
1.202 Vistas
23 Respuestas
Respuestas (23)
Emmsleys
I am going to move this post to the AutoCAD Mac board.
If you login as a different user on your system does this issue still happen?
What happens if you reset your settings to default?
Sarah Emmsley
Technical Support Specialist
0 Me gusta
No aplicable
I already reboot the computer, the program and nothing happened. The
problem continues.
I select any command, the program disappears from the screen and everything
is blocked.
I'm going to uninstall the program and reinstall it to see what happens
*JOSE RAFAEL BAYONA FLOREZ*
*ARQUITECTO*
*3103249828*
0 Me gusta
No aplicable
problem continues.
is blocked.
0 Me gusta
No aplicable
I already give up the program and reinstalled it and the problem continues
0 Me gusta
pendean
Community Legend
Community Legend
What is your MAC OS?
0 Me gusta
No aplicable
yosemite
*ARQUITECTO*
*3103249828*
0 Me gusta
saheldt
I am having the exact same problem.  Any command will cause the drawing screen to disappear and the program becomes inoperable.  I am also using Yosemite but have read others with similar problems upgrading to Sierra and having the same issues.
0 Me gusta
saheldt
I am having the exact same problem.  Any command will cause the drawing screen to disappear and the program becomes inoperable.  I am also using Yosemite but have read others with similar problems upgrading to Sierra and having the same issues.    I have also uninstalled, re-installed and reset the program to defaults twice.
0 Me gusta
No aplicable
I also uninstall and reinstall the program but the problem persists.
What does autodesk say about it?
*ARQUITECTO*
*3103249828*
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Does it crashes when you select command from ToolSets palette? What if you type command from keyboard? select it from pulldown menu?
Can you try to create new user account on your Mac, login to it and launch AutoCAD?
Does it crashes after you start to use commands in new account?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
The program hangs when I select a command in the TooLSets and in the
drop-down menu, it will not crash if I type the command.
What sense does the user have to change? The user I have is the one I have
always had registered in my autodesk account. This I have not tried,
besides I do not know how to do it, I download the program following all
the protocols.
*ARQUITECTO*
*3103249828*
0 Me gusta
saheldt
Same for me, it crashes from either the tool set palette or drop down menus.  I can try to create a new user account and see what happens.  I have sent all of the error codes and crash info to Autocad but haven't gotten a response yet.
Thanks for any help you can give!
0 Me gusta
No aplicable
I am also looking for a solution in the forum but what I find is that many
of us have the same problem
I would like to have an official autodesk response
thanks
*ARQUITECTO*
*3103249828*
0 Me gusta
maxim_k
Here is how to create new user account on Mac:
https://support.apple.com/kb/PH18891?locale=en_US
You don't need to create new Autodesk ID, just new user account on your Mac.
Later? after test you can remove this new account.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
saheldt
I just completed this test, set up a new user account and ran 2017.  Within seconds the same crash occurred.
0 Me gusta
maxim_k
What kind of lisence do you have?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
saheldt
I have a 3 year subscription.
Shawna
0 Me gusta
maxim_k
Which Mac model do you have?
Can you try to Clean reinstall AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Here is the link to the Knowledge Base article :
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
