Anuncios
problem retrieving x-ref files from zip file sent by Windows user
HEIDICLEM
HEIDICLEM
My client sends me ZIP files which include the base drawing and all of the external references needed.  Once I extract files, the only one accessible is the main file - the references do not transfer over.  We have gone around in circles on this and I am exhausted of ideas on what is happening.  Any insight from anyone?  I use AutoCAD light for MAC - they are on CAD for Windows.  TIA!
0 Me gusta
Responder
Soluciones aceptadas (1)
980 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Welcome to Autodesk Forums!
Hi Heidi,
Can you explain what is shown on the attached screenshot?
Is it extracted contents of ZIP archive in Finder? I can suspect these files are inside Dropbox folder and red cross means (most likely) that file names contain an invalid character(s):
https://help.dropbox.com/installs-integrations/sync-uploads/files-not-syncing
Indeed, look at forward slash in the file names - OS X restricts the use of forward slash characters in file names.
That is why these filed cannot be loaded as Xrefs inAC for Mac. You need to ask your client to rename them and correct Xrefs paths or you have to do this yourself.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
Unless the file sender made an effort to reassign all the xrefs full paths for you, and assuming they sent you all the files in the first place, you are going to have to do the manual fix of reassigning them in the top file yourself.
Unless you want to drop all files (XREF and top file) into one single folder, then AutoCAD will find and load them all for you automatically.
0 Me gusta
maxim_k
Solución aceptada
Sorry, I was wrong about forward slash here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/problem-retrieving-x-ref-files-from-zip-file-se...
- it is back slash. But anyway, there is something wrong in filenames or files, extracted inside Dropbox folder was not synced correctly for some other reason.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
HEIDICLEM
Thank you!
Renaming the files (removing backslash) and files matching the main x-ref manager worked!  I appreciate the response!
0 Me gusta
