Hi @Anonymous
It appears that this is missing a font so let's try a reset to see if it corrects your problem.
To reset the entire program:
Hold down the Shift key while starting AutoCAD for Mac. In AutoCAD for Mac 2015, you may click the AutoCAD menu and choose "Reset AutoCAD." For all versions of AutoCAD for Mac, do the following:
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Hi @Anonymous,
This obviously isn't a problem with AutoCAD. Here is an article I found on the web that does some serious cleaning of fonts on the Mac. Use it at your own discretion. I think you might have better luck with finding a solution on Apple's site.
I hope you can find a solution that doesn't mean rebuilding the entire system.
Hi jabaliorwa5
I am checking back to see if my post or @maxim_k helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
