Anuncios
problem in language
problem in language
No aplicable
hi;
i have this problem in laguage as showen in  the photo below:
0 Me gusta
Responder
576 Vistas
10 Respuestas
Respuestas (10)
john.vellek
Hi @Anonymous
It appears that this is missing a font so let's try a reset to see if it corrects your problem.
To reset the entire program:
Hold down the Shift key while starting AutoCAD for Mac. In AutoCAD for Mac 2015, you may click the AutoCAD menu and choose "Reset AutoCAD." For all versions of AutoCAD for Mac, do the following:
  1. Click Preferences under the AutoCAD menu.
  2. Click the Application tab.
  3. Click the button "Reset Application Options."
  4. Click "Reset AutoCAD."
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
It appears that you experimented with some of the Mac OS System fonts. Did you?
If yes, I'd recommend you to put everything back, restart your Mac and check AutoCAD again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
hi; john vellek
hi; maxim
This problem appeared in other programs.
What is the problem and what is the solution
Thank you
0 Me gusta
maxim_k
Your system fonts got corrupted for some reason.
Quit all applications.
Now use the Font Book app in the applications folder.
Use menu File -> Restore standard fonts to restore System fonts on your Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
sorry ;(
not working
0 Me gusta
john.vellek
Hi @Anonymous,
This obviously isn't a problem with AutoCAD. Here is an article I found on the web that does some serious cleaning of fonts on the Mac.  Use it at your own discretion. I think you might have better luck with finding a solution on Apple's site.
I hope you can find a solution that doesn't mean rebuilding the entire system.
John Vellek
0 Me gusta
No aplicable
I do not know.
  Perhaps the reason when I used the program clean my Mac to clean the device from viruses
I think it was deleted some language files
0 Me gusta
maxim_k
Than, I think, the best solution would be reinstalling the entire System on your Mac. You can use Recovery partition to reinstall OS X. All your files and settings will be preserved.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Here is an article about Os X reinstallation using Internet Recovery :
https://support.apple.com/en-us/HT201314
And:
http://osxdaily.com/2014/12/14/reinstall-os-x-mac-internet-recovery/
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Hi jabaliorwa5
I am checking back to see if my post or @maxim_k helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
