problem export pdf
problem export pdf
Message 1 of 22
problem export pdf
hello everyone.
I'm having problems exporting my dwg to a pdf in autocad 2014 (Mavericks).
The dwg seems pretty good, but as soon as I export it lots of fillet lines and arcs in general (but even straight lines, sometimes) are not joined or messy.
here you are some examples of what I mean:
the draw is in 1:1 (meters) and I need to export in 1:5000
Replies (21)
Message 21 of 22
no, the whole dwg!! as you seen on the video!
Message 22 of 22
maxim_k
Yes, I see. And I'm ready to repeat: the objects inside viewport became so small because you scaled them down in Model space for some unknown for me reason.
If you (as I did in last drawing posted here) will activate Model space and scale everything with SCALE command with scale factor 500, then will return to the Layout - your model will be in correct size inside viewport.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
