problem export pdf
problem export pdf
Message 1 of 22
problem export pdf
hello everyone.
I'm having problems exporting my dwg to a pdf in autocad 2014 (Mavericks).
The dwg seems pretty good, but as soon as I export it lots of fillet lines and arcs in general (but even straight lines, sometimes) are not joined or messy.
here you are some examples of what I mean:
the draw is in 1:1 (meters) and I need to export in 1:5000
Replies (21)
Message 2 of 22
pendean
Community Legend
Community Legend
Message 3 of 22
maxim_k
Hi benjanowitz,
to
In AutoCAD for Mac version you can not set resolution for vectors for PDF output as you can do in PC version of AutoCAD and as was advised here:
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/PROBLEM-WITH-COMMAND-quot-FILLET-quot/td-p/5066...
BUT!
You can use one simple trick to get output even better than on PC.
Here it is:
Create huge Custom paper size (in your file I used paper size 2100 cm x 2970 cm, save PDF from your drawing with scale 10:1 (or 1:0.1),
than open it in Preview.app (Adobe Reader can not handle such huge PDF files), then start Print it to A2 paper size with scale 2%, and select Open PDF in Preview - now you have your PDF in A2 size at 1:5000 scale (see attached)
The quality of the PDF is good.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 22
maxim_k
Hi Dean,
Thanks for pointing me there.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 22
thanks a million!!!
you've saved my life 😄
it works!! thanks!!
Message 6 of 22
maxim_k
Hi Ben,
Here is short screen cast i created in order to explain my way to create HiRes PDF from AutoCAD for Mac:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 22
Hey maxim, thanks so much for the video. It's great!
I keep doing something wrong.
When I do the scale 1:10 (1:17 of the video) my draw becomes super-tiny. and I tried to export it like that, but it's super f-up.
What am I doing wrong?
Message 8 of 22
maxim_k
Hi Ben,
The scale for viewport on the video is 10:1, but not 1:10 or 1:17.
You need to set scale to 10:1
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 22
Yes, sorry. I meant 10:1 🙂
And 1:17 is the minutes on the video! 🙂
Message 10 of 22
maxim_k
I attached your DWG with Viewport of desired scale in Layout1.
You need to have Custom paper size with name "Huge A2"  (2100cm x 2970cm with 0 cm margins) in order to be able to save to PDF this layout.
Is your problem solved?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 22
I've made a video, it's easier! 🙂
(Thanks to helping me so much!!)
Message 12 of 22
maxim_k
Could you send your video to my e-mail: mkanaev at yandex.ru ? Youtube is blocked in my office :((
And - Could you post DWG with your settings?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 22
Yeah, sure!
Message 14 of 22
maxim_k
That is because you scale down everything in Model space by 500 times for some reason.
I scaled your Model space by 500 times and everything is OK now.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 22
Sorry, what do you mean?
Message 16 of 22
maxim_k
I mean:
when I was looking at your drawing for the first time (the file from your first post here) everything was 500 times bigger in size in Model space, so I advised such scale as 10:1.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 22
Ok, so I don't need to do the step of scaling to 10:1?
Message 18 of 22
maxim_k
You don't need to touch geometry in your drawing - it should be in your usual scale: 1 AutoCAD unit = 1 meter, as it was in your first drawing.
You only need to change viewport scale in Layout an set it to 10:1 for the paper size I have suggested you.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 22
Yes, but when I change the scale in layout, it becomes tiny!
Message 20 of 22
maxim_k
Do you mean tiny lineweights?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
