Anuncios
problem dot-line print preview
No aplicable
Schermafbeelding 2016-03-14 om 16.54.53.png  Schermafbeelding 2016-03-14 om 16.55.06.png Schermafbeelding 2016-03-14 om 16.55.25.png
Problem with dot-line!!! In my model and my layout you can clearly see de dot-line. So far so good,but when i do a print preview my dot-line is a solid-line!
8 can't figure out what the problem is, can anyone help me out out please?
0 Me gusta
Responder
Soluciones aceptadas (2)
1.094 Vistas
11 Respuestas
Respuestas (11)
maxim_k
Is it a solid line when you print to the physical device?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
HI,
It looks like a solid line to me! but the strange thing is in modelspace en paperspace everything appears right? the only problem is when i do the print preview??? maybe i post my dwg here so you can check the setting? or is that a stupid question?
0 Me gusta
maxim_k
I noticed that you have "Scale Lineweights" option enabled. Try to turn it off.
I think the case is in this option, probably a bug in AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
hi maxim,
i put on my line weights but nothing changes,mayor bummer!
can i contact someone to fix the bug? cause this is a test for school!
0 Me gusta
maxim_k
Please, attach the drawing along with plot style table file (if you are using it). You need to compress plot style table file in order to be able to attach it.
Msxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
hi maxim
i gonna try to attach the file and send it to you
0 Me gusta
No aplicable
0 Me gusta
maxim_k
Solución aceptada
On my system they are dots, but lineweight seems a bit thick.
Unfortunatelly I cannot see your results as screenshots you provided are too small :cara_de_decepción:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
no problem i will take some new screenshot and post them in a bigger format
i will try and do this tonight otherwise it's gonna be tomorrow . thanks for you're help
0 Me gusta
maxim_k
Will be better to attach PDF itself instead of screenshots.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Solución aceptada
thanks for you're feedback maxim! i checked my plot style and changed my setting on the magenta color from 035 to018 and everything looks acceptable now.
thank you very much
0 Me gusta
