polar array
polar array
philobatir2017
polar array
philobatir2017
why when I use a polar array the items merge?
I created a circle with a straight line
then used a polar array
when I exited the polar array and clicked on one circle to modify the whole drawing was considered to be one item
not 4 circles and 4 straight lines.
maxim_k
Hi @philobatir2017 ,
AutoCAD creates associated arrays by default when you use ARRAY command.
You can learn more about editing such arrays here:
https://help.autodesk.com/view/ACDMAC/2023/ENU/?guid=GUID-8F59E51C-8E9D-4B24-BCD4-CA6C7726BE0D
You can create non-associative arrays with ARRAYCLASSIC command or by changing ASsociative option to No when you create an array.
You can also EXPLODE associative array after you create it, then you will be able to edit individual objects separately.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
philobatir2017
thank you so much 😊
