PLOTTING TEXT SHOWS MULTIPLE SIZES
No aplicable
I am using LT 2017 for MAC
When Plotting my drawings the text shows boxes around the text and there are multiple layers of text, some at a different orientation
While in paper space everything looks fine but when I plot to a PDF the problem occurs.
ANY Ideas
0 Me gusta
Responder
Soluciones aceptadas (1)
541 Vistas
5 Respuestas
Respuestas (5)
No aplicable
Could it be that there are background masks or wipeout boxes in which the lines around the text are visible? Maybe check that and then change the draw order of the text and send it to the back in case there is something behind it you can't see. My only other thought would be to check your plot settings an make sure there is not an override of some sort of the plot style.
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous,
Can you attach the resulting PDF? This will help me to answer your question more accurately.
For now I can suppose that:
- you are using SHX based text styles in your drawing
- the "boxes" around the text actually are notes, which AutoCAD places behind SHX text geometry to make text searchable in PDF (if you are saving DWG to PDF), the same "boxes" occurs when you print directly to the printer in AutoCAD for Mac.
If I'm correct, than you can set AutoCAD system variable EPDFSHX=0, than AutoCAD will not create "searchable" text notes and "boxes" around text should go away.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thank you plot styles seem to be correct and draw order ok
0 Me gusta
pendean
Community Legend
Community Legend
Post your PDF and dwg, let's all have a look.
0 Me gusta
No aplicable
Solución aceptada
Thank you all for your help I think I have found the problem
Apparently it is with my viewer, I sent it to a friend of mine
Embarrassing
