Plotting & PDF Issues
garyDQ34Z
Message 1 of 15
garyDQ34Z
Hi
I have a problem with plotting and saving as PDF.  As soon as I plot my drawing or save as PDF  the text & dimensions change to a series of boxes replacing the letters & numbers and the walls on the plan are printed or saved as dark splodge ??! Previous plotting has been fine using the same layout template.
See below
TIA
Screen Shot 2017-11-15 at 18.54.20.pngScreen Shot 2017-11-15 at 18.54.35.png
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
Your AutoCAD year version is...?
Your MacOS version is....?
Is the problem unique to this one file?
Or is this your first time plotting to PDF?
How is font capture set?
Message 3 of 15
garyDQ34Z
Hi Pendean
AUTOCAD LT 2017
Mac El Capitan 10.11.6
It seems to be unique to this one file.
I am fairly new to Autocad but not the first time plotting to pdf or plotting.
Not sure how to check font capture ?
Message 4 of 15
pendean
Community Legend
Community Legend
>>>...It seems to be unique to this one file....<<<
Replace the font in the file.
If it;s a stock font you use everywhere in other DWG files and they plot file, then INSERT the problem file into one that is working just fine for you (like a template), EXPLODE and plot to see if it goes away.
Message 5 of 15
garyDQ34Z
Ok great halfway there, dims and room names now plotting but walls and dim lines etc still look as the pic I posted.
Message 6 of 15
maxim_k
If you are using Plot Style table - check it, maybe something has been changed.
If you don't use Plot Style table, then check lineweights assigned to the Layers you are using in the drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 15
garyDQ34Z
Hi Maxim
Lineweights are all good on all layers & plot style table is as it should be - acadlt.ctb
Message 8 of 15
maxim_k
What about "Scale Lineweights" option in the page setup?
If you have it checked, then try to uncheck.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 15
garyDQ34Z
Hi Maxim
It's unchecked already
Message 10 of 15
maxim_k
Can you attach the problem drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 15
garyDQ34Z
Attached drawing below.
Message 12 of 15
maxim_k
The objects which have "incorrect" lineweight in output have lineweight 1.00 mm - you can check this by selecting one of such object in the drawing and looking at its properties in the Properties palette:
I also noticed that current lineweight in your drawing is also set to 1.00 mm for some reason.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 15
garyDQ34Z
Thanks Maxim
I haven’t changed any lineweights, I thought they were all set to default, is the default setting no good ? Appreciate your help
Message 14 of 15
maxim_k
Lineweights can be assigned as Layer property. You have them all "Default".
If an object has lineweight property assigned "ByLayer", then it takes lineweight from the layer in which it resides.
If an object has lineweight assigned to some value, as some of the objects in your drawing, then this value will be used to represent object's lineweight. That is why some objects in your drawing have "incorrect" lineweight.
Now about current lineweight - if it is set to "ByLayer", all newly created objects in the drawing will be created with lineweight property "ByLayer". If lineweight set to some value, for example to 1.00 mm as in your case, all newly created objects will take this (1.00 mm) lineweihgt regardless of the layer on which they are located.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 15
garyDQ34Z
Thanks Maxim
