Plot styles
Plot styles
Plot styles
I am trying to have my paperspace layouts in black and white for plotting and exporting as PDF. Ive tried editing my page set up. In the plot style table I have selected monochrome.stb, autodeck-MONO.stb, and others. When I select monochrome.ctb it says monochrome.ctb (missing) in the name. When I select the ones that don't say missing I select display plot styles option, select ok. Ive tried to set current before closing the page setup manager. Nothing ever changes. My PDFs come out in color. Any help would be greatly appreciated.
Thanks very much for your time,
Adam
maxim_k
Welcome to the Autodesk Forums!
Hi Adam,
If monochrome.ctb listed as missing in the Plot Style table dropdown in the Page Setup Edit window, than it appears it was deleted for some reason from the "Plot Styles" folder. Tho check this - use "Reveal in Finder" menu to open "Plot Styles" folder in finder.
If it is really missing, you can try to reset AutoCAD settings using menu "AutoCAD" -> "Reset AutoCAD". This should reset all settings to default and restore original plot style table files, including monochrome.ctb
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi adamsnodgress
and welcome to the Autodesk Community!
I have attached a copy of my monochrome CTB if you want to drop it in your plot styles folder. Alternatively, it is easy to create a new one. In the Plot Styles, click on new. Select all the colors on the left and assign them to Black on the right hand side
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi adamsnodgress,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
