Hi there,
I'm a student still learning, on Windows in the classroom but Mac at home.
The teacher gave a title block to XRef into paper space:
So, when working on windows I would normally make the following selections to resize the title block to fit the paper space:
1) Command: Plot
2) Select paper size (A3)
3) What to print - select window - select title block in paper space
4) Center plot
5) Fit to paper
6) Apply to layout
But, when working on my Mac I only have a an A4 printer so can't select A3 and there isn't an "apply to layout" option which would allow me to go back into the paper space to continue working:
I thought of trying to install a pdf printer driver to access an A3 option, but the Mac has it's own built in pdf function and won't install and Adobe driver. I know I can edit the page set up to get A3 and center the plot, BUT I still can't figure out how to "apply to layout" then continue working in paper space. Why does it only give the option to print?
I would be so grateful for any help and advice.
Thank you, thank you, thank you...
