please teach me differences between "import pdf" and "attach pdf underlay"
I want to insert pdf data into autocad, and scale contents of pdf data.
When I research that method, I find method of "import pdf" and "attach pdf underlay".
But I can't understand difference. So please teach me.
If I have any rude and expression, I'm sorry.
And because I usually don't use English, please teach me easy to understand.
maxim_k
Hi 田辺 明毅,
When you import PDF, AutoCAD attempts to convert all vector data in PDF file to AutoCAD objects (lines, arcs, polylines, text, etc) and place them to the drawing. So after you import PDF, its contents became the part of the drawin and there is no need to keep PDF alongside the DWG file. This method works fine if all data in PDF file is in vector format.
When you attach PDF, AutoCAD inserts it as external reference, the same way as raster image file. After you attach PDF, you need do keep it alongside with the drawing in order AutoCAD can find and load it each time you open the drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @Anonymous,
Did @maxim_k's post get you the information you needed regarding the two different methods of working with PDFs? If so, please mark his post as the solution. If you require more information, please provide some more detail and I will be happy to help you.
John Vellek
