PDF Problem AutoCAD LT for MAC
No aplicable
Dear All,
I am working with the AutoCAD LT for MAC, an have a problem with PDF export print. When I try to plot the layout, everything working fine, but when I try to open the PDF document I see the slide empty , .. don't see anything on the PDF document. Please, anyone could you help me about this ?
Alberto
Thanks in advance.
0 Me gusta
Responder
493 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Welcome to Autodesk Forums!
Hi Alberto,
which AutoCAD LT version you are using?
Is it correct that you can print the Layout on printing device, but cannot see PDF saved from the same Layout?
If - yes, than what application do you use for viewing PDF?
If - no, than:
Do you use Preview button in Print window to create PDF file or you are using Batch Publish?
Have you created Page Setup in Page Setup Manager for the Layout you want to save to PDF?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Mac, I am using the AutoCAD LT 2017 FOR MAC. When I finished my layout, I printed my sketch ( Of course save as PDF document on my folder ). Then try to see my sketch, the PDF is open but are empty. Could be an problem coming from Adobe PDF program ?
Best Regards,
Alberto
0 Me gusta
maxim_k
I think the problem could be in fact that you have not created Page setup for the Layout you want to print (save to PDF) with Page Setup Manager and haven't set it current. As a result you get an empty area of your drawing in PDF output.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Did setting up a page setup help with your plotting to PDF issues?
Sarah Emmsley
Technical Support Specialist
0 Me gusta
Emmsleys
I'm following up on my previous post, If you have any questions or found a workaround post back with any new updates
If you still need help or have questions I'll be more than happy to help.
Thanks.
Sarah Emmsley
0 Me gusta
