Anuncios
PDF Exporting Incorrectly
No aplicable
For reasons unknown when I export my drawing to PDF only some of the objects show up. All my layers are turned on. In fact, my layout and model look identical. It's just when I export the PDF it is incorrect. I should add that exporting other maps I have created in the past still work so I'm thinking I tweaked this drawings settings without knowing. Exporting to JPG and PNG work; however, I prefer not to use them. Furthermore, I have updated all my pdf software so I believe this is an AutoCAD problem. Has anyone had this issue or know how to help? Thank you
UPDATE: It's only one of my layers that isn't exporting. Hope this helps
0 Me gusta
Responder
458 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Which application you are using for viewing PDF files?
If it is Preview app - have you tried to open PDF in Adobe Acrobat Reader?
Do you have objects with zero lineweight in your DWG file?
If yes, than these objects could be "invisible" in Preview app (or other "native" OS X PDF viewing applications, such as PDF Expert), but in fact they are here and you can see them in Acrobat Reader.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Is this happening with multiple files?
Would you be able to share maybe a sample of the file so that I can test it on my AutoCAD?
Sarah Emmsley
Technical Support Specialist
0 Me gusta
