Paper space and model space object scale issue.
CoryBriz
CoryBriz
I am new to using layouts for my drawings.
My problem is when in my model drawing i have a whole plan w/ multileaders and when I look at the drawing in my layout they are all gone?
Also my line type scales are all messed up?
Im sure this is a easy fix, but some help would be much appreciated! Thanks
0 Me gusta
Responder
706 Vistas
9 Respuestas
Respuestas (9)
maxim_k
If you don't see some objects in the Viewport in the Layout at first verify that all layers are turned in and not frozen in this Layout.
About Linetype scale issue: which value has PSLTSCALE system variable in the Layout?
You can also attach your problem drawing - I'll look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
CoryBriz
Thanks for the reply, the layer for the multileader text is on and not frozen but still is not showing. also, how do you post screen shots to the forum
Thank You!
Cory Brizendine
Cell: 619-606-4662
WEB: westpointcustomhomes.com
WEST POINT CUSTOM HOMES
0 Me gusta
maxim_k
Take screenshot, than attach it to the post.
The issue with multileaders could be related also to Annotative scale feature
https://knowledge.autodesk.com/support/autocad/getting-started/caas/CloudHelp/cloudhelp/2016/ENU/Aut...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
CoryBriz
Great! so I changed the Multileaders Annotative to Standard and it fixed the issue. Thank you. My only other issue is the line type scale is different from model to my layouts. I have a dotted line that is perfect in my model and its a solid line in my layouts??
Thank You!
Cory Brizendine
Cell: 619-606-4662
0 Me gusta
maxim_k
I already asked you:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
CoryBriz
Its 1
0 Me gusta
CoryBriz
Are you asking me what the value is? Not sure how to check which value has PSLTSCALE system variable in the layout... where do I look for that? and do I need to check if its the same in model?
0 Me gusta
maxim_k
Try to set PSLTSCALE to 0 (zero):
While in the paper space in the Layout type at the command prompt PSLTSCALE, hit Return, than type 0 (zero) and Return again.
Now use REGENALL command to see the results.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the
Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
0 Me gusta
