pan mode gets stuck.
No aplicable
Same thing happens to me. Editing single line text at the moment when suddenly I miss click and my pointer because a 'pan' hand and I cannot escape the command or close the drawing without force quitting. Which loses changes. The is no X button in upper left corner that creates the response you anticipate.
This Post was split by john.vellek from a similar one in the AutoCAD forum
0 Me gusta
Responder
2.663 Vistas
6 Respuestas
Respuestas (6)
VinodBalasubramanian
Autodesk Support
Autodesk Support
Hi there,
What version of AutoCAD you are running?
What OS do you have ?
Let me know.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
0 Me gusta
No aplicable
AutoCAD LT 2014. OS is El Capitan 10.11.6
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
Here are the system requirements for AutoCAD for Mac. Please verify that your system is compliant. Also, please make sure that you have your AutoCAD fully updated from here.
John Vellek
0 Me gusta
maxim_k
Hi Mari,
Have you tried to quit PAN mode by hitting Spacebar instead of pressing "Esc" key?
Next time when the PAN mode will get stuck, try simply hit Spacebar on keyboard, this should return you to current AutoCAD command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI @Anonymous,
A workaround might be to hold the middle button down and then release it. Does this quit the PAN command?
John Vellek
azmand01!e
This is an old post.. but this problem is presistent with every version of ACAD I used all these years.
It can sometimes be related to amount of RAM.
The more RAM you have the less it happens. Yet still happens no matter how much RAM I use.
It seems to me that is related to software response.
0 Me gusta
