I've recently downloaded the trial version in my MacOs Monterey 12.0.1. The big issue is that when I try to enter a specific measurement for a line it disregards my command and ends the line wherever my cursor is, it's like the command ENTER doesn't work at all.
Many thanks
Solved by rkmcswain. Go to Solution.
To clarify, you are picking a start point, then releasing the mouse (which specifies the direction), then entering a distance and pressing enter (or whatever the command completion key is)?
Hi, thank you for the quick reply.
I tried to follow the order of the operations you indicated in the question that is: release the mouse before entering the measurement...I tried and it worked. I've tried a lot of times unsuccessfully, maybe I was doing something wrong. It seems to work now.
Thank you very much
