Anuncios
Multiline Text overlapping when pdf/printed
MarkTimmsArchitect
Observer
MarkTimmsArchitect
Observer
Observer
Hi
I've search the forum and cant seem to find a specific solution?
I have a paperspace title block which is filled with a multiline text box, split into 4 columns. In paperspace this looks perfect, but when I pdf or print, the text in all columns overlaps? I'm using a TT font.
As I would like to be able to adapt the text in the future, I would rather retain the columns. The font used is part of our branding, so ideally would prefer not to change the font...
Just wondering if I've missed some sort of acad setting, rather than the only other option I can think of, which would be to separate the text into 4 separate text boxes. Which is a real pain if the text needs to be amended.
Thanks for any help in advance!
Mark
0 Me gusta
Responder
Soluciones aceptadas (1)
649 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi @MarkTimmsArchitect ,
What AutoCAD version are you using?
Have you installed all updates (if any) to it?
What printer do you use for saving to PDF?
Have you tried to use "Convert all text to geometry" option in Printer settings?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
MarkTimmsArchitect
Observer
Observer
Hi Maxim
Thanks for the reply. Changing the printer to Autocad pdf solved the issue!
By default, it's set to my HP printer. Printing or using the 'preview' button to create pdf, created the text overlap.
PS. Using Autocad LT for MAC 2022.2.1
Mark
0 Me gusta
