Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
mtext rotated 270 degrees
6 REPLIES 6
1411 Views, 6 Replies
just opened my drawing that I have been working on for about a month and noticed that the text is rotated to default at 270 degrees.  Typically, I would just ignore it but it has become quite the annoyance when I want to actually rotate the text.  I have looked through the forum and have tried everything suggested that seemed to work for others including; changing the font to Arial, changing settings on MTEXTFIXED, making sure my display settings are correct, and I have a "world" ucs, and nothing seems to work.  Can anyone help me with this new issue?  I am using a MAC
Labels (1)
6 REPLIES 6
Patchy
Ask the mac forum
Valentin-WSP
@Anonymous ,
Please provide an image with the UCS icon.
(UCS = World  and  PLAN = World)
Consider AutoCAD reset.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
as requested image with ucs icon and command showing "world"
Valentin-WSP
@Anonymous ,
Try changing the Direction Control in the Drawing Units dialog and see if it makes a difference on the properties rotation.
Consider posting on the Mac Forum: https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520/page/137
Emilio Valentin
maxim_k
Hi @Anonymous,
What about the coordinate system in the drawing?
Is it WCS or UCS?
Do you have this problem in all of your drawings? Even in newly created with the default acad.dwt template?
Can you share this drawing here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: Valentin-WSP
That did it!  I changed the direction on another drawing, not sure why it went to this one.  Either way, that was the solution! Thank you!
