Moving base point of block
No aplicable
how can i move a base point of a block without opening the block? I want to move the base point of several blocks to a special position in the layout. That means I will have to move the base point just in the layout, without moving the block.
May somebody have a good idea, without exploding the hole block.
0 Me gusta
Responder
Soluciones aceptadas (2)
8.559 Vistas
9 Respuestas
Respuestas (9)
maxim_k
Open block in Block Editor, move the contents of the block with base point where you want new insertion point to 0,0 inside Block Editor.
Save block, exit Block Editor. Now move all blocks to the desired position.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
thanks, but i want to move the base point without opening the block editor! Is this somehow possible?
0 Me gusta
maxim_k
Solución aceptada
You can use "Edit Block In-place" from context menu when block is selected.
Move the block contents to the new position (you need to know where old insertion point was located and use it as base point for MOVE command). Than save block with the button on the Visor.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hey maxim,
thanks a lot i will try it out and let you know!
0 Me gusta
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the
Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
0 Me gusta
john.vellek
Solución aceptada
HI @Anonymous,
Another, and older school, method is to wblock the block out of the drawing. Then open it and then use BASE to relocate the insertion point. Then you can insert back into your original drawing (if you purged it out or substitute insert the block)
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
No aplicable
Gentleman, sorry for that late reply. I was out for some weeks.
@maxim_k thanks a lot again for the good help.
0 Me gusta
No aplicable
Hi John,
will try this out too. Thanks again.
0 Me gusta
