Anuncios
Mouse not registering on screen until clicked - Autocad 2016 for MAC
No aplicable
When I load AutoCAD on my macbook pro, the cursor on screen does not register movement until clicked and then it is able to make lines smoothly.
The issue is that without being able to see where the mouse is going I cant draw efficiently. Panning and zoom still work as normal.
All I can imagine is that the macbook is struggling to recognize the drawing window in AutoCAD thus causing this weird lagging effect.
I have been running windows 10 on the mac to get around this so I know the macbook is capable of running the software well.
Have looked everywhere for a solution and I'm completly baffled by this issue.
Any help appreciated.
Kurtis
0 Me gusta
Responder
Soluciones aceptadas (1)
1.123 Vistas
14 Respuestas
Respuestas (14)
Alfred.NESWADBA
So what operating system is it, that shows the issues then with the cursor/mouse?
If it's Mac-OS then you should better ask in the AutoCAD for Mac forum >>>there<<<.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
wispoxy
If you switch between layout tabs and back to model space does it stay registered?
0 Me gusta
No aplicable
The issue is happerning in Mac OS X El Capitan.
Thanks in the future I will post there.
0 Me gusta
No aplicable
Nope, just tried that and it is still not registering mouse movement until clicked.
0 Me gusta
wispoxy
Have you played around with the visual or graphic settings? and share your graphics card please.
0 Me gusta
No aplicable
Yeah ensured hardware exceleration is on etc. Also this is the standard 13 inch MacBook Pro retina, built in Intel graphics. Im pretty sure its not an issue with the graphics chip as many of my freinds run the exact same version on the exact same laptop.
0 Me gusta
wispoxy
New apple laptop hardware is updated like every 2 - 4 months. Unless you bought it around the same time period, from the same factory line, factory new, not used. I doubt it's exactly the same.
I had the same glitch with my mac autocad 2015 and I fixed it quickly, don't remember how though :cara_neutral: Didn't have to reinstall or anything like that.
0 Me gusta
No aplicable
Hmm I don't know I cant find a solution online to this issue, will continue to search.
0 Me gusta
maxim_k
Hi Kurtis,
Do you mean you cannot see crosshairs in the drawing area when you move the mouse over it?
Have you tried to reset AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ntombling
Solución aceptada
I have a few questions that may present a few more ideas
- Are you using the Trackpad? If not, does it behave the same way with the Trackpad?
- If you are using a mouse, which one (are its drivers up to date for El Capitan)? If you have access to a different one, please see if it behaves the same way.
- Do you have a graphics tablet installed and/or plugged in?
- I note you are also a Windows user. Do you have any 3rd party mouse utilities installed to change mouse behaviour?
If you are using anything other than the Trackpad, have a look in the System Preferences for any options that may alter mouse behaviour. While I don't have El Capitan, 3rd party control panels could be along the bottom line. Also, have a look in Trackpad, Mouse and Accessibility (and I think OSX also has a graphics tablet/pen one too) for anything that can be toggled and tested.
AutoCAD also has several settings that may or may not help the matter.
- You can reset AutoCAD for Mac to defaults (scroll down for Mac instructions)
- In AutoCAD Preferences under General, try toggling off OpenGL (in the Graphics section)
- In AutoCAD Preferences under Cursor and Selection, try changing colours, length and sizes of the crosshair
- In AutoCAD Preferences under Units and Guides, try toggling coordinate display, autotrack settings and fields
- In AutoCAD drawing space, try toggling dynaimc input, polar tracking and object snap tracking
Hopefully there is something here that can assist alleviate your problem until a proper solution is found.
0 Me gusta
No aplicable
Yeah the crosshairs don't show at all until the screen is clicked, as you can imagine this makes drawing impossible.
I have also completed a full fresh install of both my OS and AutoCAD and neither of these steps made any difference.
0 Me gusta
No aplicable
Also ntombling I just tried all of your suggestions and none of them worked either, thanks for the comprehensive answer though.
0 Me gusta
maxim_k
Hi Kurtis,
If you installed OS X and AutoCAD FRESHLY, WITHOUT ANY OTHER THAN AutoCAD applications, than I'm afraid, I cannot help you.
Unfortunately I cannot test AutoCAD 2016 on Macbook Pro Retina 13", because I don't own such Mac model.
I have not seen complaints from the other users of AutoCAD for Mac 2016 on standard Macbook Pro Retina 13" here and cannot imagine that you are the only one who have such issue on the hardware you own.
Your problem in my opinion can occur in two cases:
- You have problems with hardware
- You have installed some software (or some settings) on your Mac that conflicts with AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
I finally managed to sort this issue out today! no idea how to be honest but its working perfectly now, thanks for the help.
0 Me gusta
