Anuncios
monochrome.stb for Mac not working
No aplicable
Hi, I'm new to Autocad. I've looked into tutorial videos and everything but I can't solve my problem. When I try to print in monochrome, it just prints in color. I have Autocad 2019 for Mac. I also attached the .dwg. Thanks
Screen Shot 2021-08-23 at 6.50.40 PM.pngScreen Shot 2021-08-23 at 6.51.12 PM.png
0 Me gusta
Responder
Soluciones aceptadas (1)
906 Vistas
8 Respuestas
Respuestas (8)
maxim_k
Hi @Anonymous ,
In order to be able to print in B&W with monochrome.stb, you need to assign "Style 1" Plot style to all layers in your drawing:
Try to print attached DWG.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi @maxim_k ,
I don't see the column that you see in your Layers window. Is it called "window" or what's the proper name? Why does it show on your screen and not in mine? How do I add that column to my setup?
Thank you
0 Me gusta
maxim_k
Solución aceptada
Hi Dario,
1. Right-click on the Layers list caption area
2. And select Plot Style column to display it
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
@maxim_k   Thanks a lot for taking the time to reply. You resolved the issue.
0 Me gusta
No aplicable
By the way, this issue occurred because when starting Autocad I had selected the "acadISO - Named Plot Styles.dwt" option. If I select another option like "acadiso.dwt" this issue doesn't occur.
0 Me gusta
maxim_k
Yes, in AutoCAD you can use two different types of Plot Style tables: color-dependent and named.
Most users (and me too) prefer to use Color-dependent plot style tables (CTB).
You can read more about Plot Style tables in AutoCAD here:
http://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-2FD01085-DDD8-49D2-A910-E63EA45A7FED
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thanks, do you know of any good free video tutorials/courses for Autocad for Mac? I found many online but it's hard to find good ones that explain things in a through manner.
0 Me gusta
maxim_k
Hi @Anonymous ,
You can start here:
https://www.linkedin.com/learning/search?keywords=AutoCAD+for+mac&upsellOrderOrigin=default_guest_learning&trk=homepage-learning_learning-search-bar_search-submit
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
