Anuncios
Monochrome does not print black
No aplicable
I cannot print black even when setting the plot style table to monochrome.Screen Shot 2019-03-06 at 10.32.27 PM.png
0 Me gusta
Responder
Soluciones aceptadas (1)
940 Vistas
10 Respuestas
Respuestas (10)
S.Faris
Autocad for MAC forum is over here
SALMANUL FARIS
0 Me gusta
ian.mag
Hey @Anonymous ,
Are you using index or true colour for your layers?
Monochrome only works with index colors, since the file extension is .ctb
0 Me gusta
dennis_collin
As you are using a Named Plot Style Template (that uses STBs) you need to ensure your Layer settings are set to an appropriate plot style type such as SOLID ,or if overridden via properties.
When using STB's I tend to use a customised copy of the Autodesk-Mono STB file.
If instead you prefer to use the more traditional CTB method of plotting, then use the CONVERTPSTYLES Command
0 Me gusta
abdelhalim.bousmaha
Check if the viewport is 2D Wireframe and not conceptual or realistic.
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
No aplicable
Where do I change this setting?
0 Me gusta
maxim_k
Solución aceptada
Hi Ron,
As you are using Named Plot Style (STB) you need to adjust Plot Style table settings for Layers and objects in your drawing.
Here is one of the ways.
Start with Model Layout and edit current Page Setup:2019-03-08_09-36-22.png
Select Monochrome.stb plot style table and answer "Yes" to assign it to all Layouts (if AutoCAD will ask you)
Then select all objects in Model and check in Properties palette that Plot Style is set "By Layer"
Then ensure that Plot Style column is visible in Layers palette:2019-03-08_09-44-08.png
Select all Layers in the Layers palette and switch Plot Style to "Style 1"2019-03-08_09-48-07.png
Now switch to Layout and select all objects in the Layout - check in Properties palette that Plot Style is set "ByLayer" by selecting everything in the Layout and looking at the Properties palette.
Now try to Print (Preview).
You can also attach your drawing here, I can look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
That worked! Thanks
0 Me gusta
No aplicable
Now my plotter is only applying color on new objects I place in the drawing. Any ideas?
0 Me gusta
maxim_k
Please verify that newly created objects have plot style assigned ByLayer
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
