Hi Ron,
As you are using Named Plot Style (STB) you need to adjust Plot Style table settings for Layers and objects in your drawing.
Here is one of the ways.
Start with Model Layout and edit current Page Setup:
Select Monochrome.stb plot style table and answer "Yes" to assign it to all Layouts (if AutoCAD will ask you)
Then select all objects in Model and check in Properties palette that Plot Style is set "By Layer"
Then ensure that Plot Style column is visible in Layers palette:
Select all Layers in the Layers palette and switch Plot Style to "Style 1"
Now switch to Layout and select all objects in the Layout - check in Properties palette that Plot Style is set "ByLayer" by selecting everything in the Layout and looking at the Properties palette.
Now try to Print (Preview).
You can also attach your drawing here, I can look at it.
