AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
MLEADERSTYLE Detail Callout problem
5 REPLIES 5
523 Views, 5 Replies
I used the command MLEADERSTYLE and changed 'Type' from "Mtext" to "Block" and 'Source Block' to "Detail Callout". The problem that I am facing is that when I create the MLEADER, the Sheet Number on the bottom of the callout extends beyond the circle. I would like to have it remain in the circle. Is it possible to scale the text down within the detail callout?
5 REPLIES 5
pendean
The circle does not auto-size to fit long text entries: are you hoping it will do more of that?
in reply to: pendean
Yes I was hoping it would, or I was hoping there is a way to decrease the text size. To work around this maybe I will leave the bottom text blank and just put a text box over it if there is no other way.
maxim_k
You can edit the default "Detail Callout" block with BATTMAN command and reduce the size of the text or change its width factor.
Alternately you can create custom "Detail Callout" block and assign it to Mleader style.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @ jau827,
Were you able to find a solution or a workaround? It's been a few days since you posted in this thread.
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
in reply to: Emmsleys
You can convert the attribute to multi-line text and then give it a background mask. This will break the bubble as shown in the attached image.
