Missing Menu's, tool bars and everything!
jewelwingstudio
jewelwingstudio
As you can see from this screenshot, I have been working successfully on AutoCAD 2017 on my MacBook Air, but then suddenly last night it glitched and I lost all controls that are normally on the left and right side of the screen, as well as the menu bar at the top. Help! I can still draw and do some things, but I can't work with layers etc.
I downloaded and installed AutoCAD for Mac 2017 last August, the first AutoCAD version I've ever had. I have not had any recent updates to my computer.
What went wrong, and how do I fix it? Do I have to uninstall the program and reinstall it?
TIA!!
john.vellek
Hi @jewelwingstudio,
Have you tried a Reset? Go to the top of your AutoCAD Window and look for the AutoCAD 2017 menu, drop it down and select Reset AutoCAD. You can also perform a Reset by holding the SHIFT key down when launching AutoCAD. Let me know if this helps to resolve the issue.
John Vellek
john.vellek
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
jewelwingstudio
Hi John,
Thank you for your reply. I did not know there was a reset button. Before I got your reply, I went ahead and uninstalled the program and reinstalled it. It seems to work fine now.
If it happens again, I'll try the reset trick!
jewelwingstudio
Hi John,
I have another problem now. When I re-installed AutoCAD for Mac on my MacBook Air, I downloaded the 2018 version because, well, it was there. I worked many, many hours over the weekend on my project.
But now I'm in class again this morning, and I tried to upload my file to the school computer so I can use it on the laser (and so my teacher can grade it), but I'm getting the message that the school's computer can't open it because it was created with a more recent version of AutoCAD. It's telling me to download DWG TrueView from the Autodesk website.
However, as far as I can tell, there isn't a DWG TrueView available for Mac. What do I do?
Thanks!
jewelwingstudio
Oh, never mind. I figured it out. I just saved my file as an earlier version using "save as". I feel like kind of an idiot asking the question in the first place now. 😕
