Missing Calculator?
Missing Calculator?
Missing Calculator?
I'm looking for the calculator in AutoCAD for Mac 2021. I haven't use Autocad regularly since 2011 and that was with a windows version so I am still working my way around. I see the quickcal command, but the calculator isn't pulling up. Please help?!
maxim_k
Welcome to Autodesk Forums!
Hi Danny,
QUICKCALC command is not available in AutoCAD for Mac.
You can use command line driven CAL command instead.
If you are using full AutoCAD version, you can try AutoLISP calculator I attached to my post.
Unzip both files - CALC_ENG.LSP and CALC_ENG.DCL to a folder on AutoCAD Support Search path and use APPLOAD command to load CALC_ENG.LSP. Try new CALC command.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
