Missing Alignspace command
raulbric
raulbric
I need to center and align the images in viewports from different layouts. I thought that the best way could be to use the command Alignspace to align each image to the viewport and this way make sure that they are in the same position. But this command is aparently missing. I am using Autocad 2022 on a Mac.
Thank you for any help
maxim_k
Hi @raulbric ,
ALIGNSPACE is an Express Tools command and not available on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
joseroque004
Observer
Observer
Is there a work around this? (another command or a way to do it)
pendean
Community Legend
Community Legend
Is this the same exact modelspace image (or images) in each of those various layouts? if yes, fix locations in one layout manually, the COPYBASE / PASTECLIP that viewport(s) using a common insertion point in all the layouts.
maxim_k
Hi @joseroque004 @raulbric ,
You can try attached LSP - download attached archive and extract ALIGNSPACE_MAC.lsp from it.
I tried to adapt aspace.lsp from Express Tools for use in AutoCAD for Mac. My LSP has minimal error checking, but basically it should work correctly.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
